PROBLEM
The CTRL F find popup doesn’t show enough text due to being too narrow. No tooltip either, so if the node has a long name it can’t be found in the case of multiple nodes being named similarly.
SOLUTION
Make it as wide as the longest node name. It doesn’t really matter if it’s the width of the entire monitor.
