Hi, so I’ve got the problem that git tells me that the subproject commit on my custom branch has been changed, even though I already merged with main and ran make update.
>git diff main lib/windows_x64
diff --git a/lib/windows_x64 b/lib/windows_x64
index ab368c849a0..a5521c85e03 160000
--- a/lib/windows_x64
+++ b/lib/windows_x64
@@ -1 +1 @@
-Subproject commit ab368c849a05d03de613764ab9739d2e16a41643
+Subproject commit a5521c85e03bfd1556ff1e63bf7163235c401497
How do I make it match main again?
Edit:
I found out that the problem was actually caused by git worktree.
When merging from a working tree into main it will merge everything except for submodules, which lib/windows_x64 happens to be.
For some reason using wildcards such git add * won’t add the changed submodules (might be a bug in the Git version I use?) bit using git add lib/windows_x64 will stage the changed submodules for commit.
Commiting then makes the local branch have the same submodules as main.
