I opened up a 2.82a project rendered in Evee. (which has sampling)
I switched it to cycles… the Sampling panel is gone. So I can’t adjust samples.
Also for both Evee and Cycles, the properties to change CPU is gone too.
Never mind… figured it out.
I was filtering the workspace and didn’t have Render Engine checked.
I would assume the render engine was a given, should always be on…
But, now I know to check it.
