Hello,
I have trouble building Blender as a Python module on Ubuntu 20.04, according to the documentation on Building Blender/Other/BlenderAsPyModule - Blender Developer Wiki.
After following the manual, that is, cloning from GitHub to blender-git/blender
and using svn
to blender-git/lib
, and installing gcc-11
as I had just gcc-9
, and running make update
in blender-git/blender
, the command make bpy -j 1
produces this output:
-- Generating done
-- Build files have been written to: /home/tomtom/git/blender-git/build_linux_bpy
Building Blender ...
make -s -C "/home/tomtom/git/blender-git/build_linux_bpy" -j 12 install
Consolidate compiler generated dependencies of target bf_intern_clog
Consolidate compiler generated dependencies of target bf_intern_guardedalloc
[ 0%] Generating libwayland/xdg-activation-v1-client-protocol.h
Consolidate compiler generated dependencies of target bf_intern_memutil
Consolidate compiler generated dependencies of target datatoc
Consolidate compiler generated dependencies of target bf_intern_opencolorio
Consolidate compiler generated dependencies of target bf_intern_sky
Consolidate compiler generated dependencies of target bf_intern_dualcon
Could not open input file: No such file or directory
make[3]: *** [intern/ghost/CMakeFiles/bf_intern_ghost.dir/build.make:110: intern/ghost/libwayland/xdg-activation-v1-client-protocol.h] Error 1
[ 0%] Built target bf_intern_clog
make[2]: *** [CMakeFiles/Makefile2:3048: intern/ghost/CMakeFiles/bf_intern_ghost.dir/all] Error 2
make[2]: *** Waiting for unfinished jobs....
Consolidate compiler generated dependencies of target bf_intern_eigen
[ 0%] Built target bf_intern_memutil
[ 0%] Built target bf_intern_mikktspace
[ 0%] Built target datatoc
[ 0%] Built target bf_intern_guardedalloc
Consolidate compiler generated dependencies of target bf_intern_iksolver
[ 1%] Built target bf_intern_sky
[ 1%] Built target bf_intern_opencolorio
[ 1%] Built target bf_intern_dualcon
[ 1%] Built target bf_intern_eigen
[ 1%] Built target bf_intern_iksolver
Consolidate compiler generated dependencies of target bf_intern_libmv
[ 2%] Built target bf_intern_libmv
make[1]: *** [Makefile:166: all] Error 2
make: *** [GNUmakefile:368: all] Error 2
Any clues?
I have also tried running the script blender-git/blender/build_files/build_environment/install_deps.sh
, but this one gives me another error:
Reading package lists... Done
Building dependency tree
Reading state information... Done
Note, selecting 'libfontconfig1-dev' instead of 'libfontconfig-dev'
E: Unable to locate package libdecor-0-dev
E: Unable to locate package libshaderc-dev
E: Unable to locate package libpystring-dev
ERROR! apt-get failed to install requested packages, exiting.
I don’t know if install_deps.sh is supposed to run on older versions of Ubuntu, but I assume it is not important as the first error mentions a file simply missing in the git repository.
