Ah nice. My proposal is two years old and got only 9 upvotes
And I just saw there is yet another from 6months ago with seven upvotes. We should funnel all individual upvotes into the most active proposal. Does RCS have a way to report duplicates and request merges? @pablovazquez
Blender can let you set edge length (with mesh tools addon).
But that is it. Yes it would amazing if I can just edit dimensions of selections in edit mode.
Right? Thereâs already a transform panel, conveniently letting you type in new XYZ info⌠unless youâre in edit mode. Itâs such an omission it would feel like an oversight, but I was honestly shocked at the pushback of âwhy would you ever want to know the distance of a selection, or scale a vertex selection to a specific distance?! Use the ruler!â
Like, really?
(Itâs awesome that blender has a ruler tool. Number of times I ever used a ruler tool in any other 3D software: I think probably never. Because I didnât have to use a ruler tool.)
yeah I think that is just blender culture. I was kind of the same until a met someone who wanted to migrate from c4d to blender and showed me how cool it is.
Besides C4D and Blender I used two other major programs for at least one year (most +3years at some point) as my main programs in daily use. I asked the question on other program forums as well yet to me it simply seems that this âŚ
a) ⌠never even crossed the minds of most people working with the program
b) ⌠never crossed the minds of the devs either and they canât see this being useful, unexplicably.
Mostly only people coming from C4D eever immediately agreed with me. XD
The only way I can explain it for myself is that you get so used to your daily workflow in (Program X) that you just accept every quirk and workaround as at least okay because you know your way around it. I can safely say from asking for this on more than one forum (where the devs also read) - itâs not just a Blender thing. It seems like it simply is one of those unexplicably overlooked simple yet crazy powerful features nobody notices for some reason.
Whatâs weird to me is that unlike other feature requests this seems to be also rather unintrusive - it doesnât change anyones workflow who doesnât need it. And also seems like rather low hangig fruit in terms of complexity.
It really only has to have two settings:
Global scale (the scale in raw scene values), Relative Scale (the scale relative to the objectâs main scale)
Bonus for adjusting and showing the boundingbox rotation of the current selection based upon the gizmo setting for local or global transform. With that it would even already surpass C4D and be a Blender thing. The most important thing about practical usage is just: The transform values have to update and be editable in realtime like for any other transform Vector3 field.
A âuserâ term represents âa person who is got used for somethingâ. A piano user is a person who is got used to playing piano, a guitar user is a user who is got used to guitar.
If there is absence of a some kind a functionality in some software, its userâs skills naturally grows to avoid that.
For example, Blender never had a basepoint snapping, so entire movies was made without it.
Any software that exists is a collection of a solutions and decisions which was made by some people at the time, some of them are successfull, some of them has critical flaws. For example, industry standards is something like Windows XP for hackers - a very well known platform which is easy to hack and outperform. This is why workflow designers, who analyse software for a wide range of a workflows, exists.
At the moment there are no wide range workflow designers to consult developers in Blender crew, and devs are consulted mostly by specialists who performs a limited workflows, like animators.
@mano-wii is it possible to add numeric input in the direction of a basepoint snapping?
For example, you start grab, set basepoint source, hover over target, then type â3 enterâ, and it translates the selection at 3 meters in the direction defined by source-target vector? (In case if no other axis restriction added during operation)
Same thing could be possible for rotation for example - a source-target vector could represent a custom axis of a rotation.
I feel like this is a task someone other than a core dev could very well try to tackle, if they knew about it.
Update:
Navigation during transform is now enabled by default.
The default transform modal maps have also been changed.
Hi.
Thank you for updates)
I think that numeric input support in the direction of a diagonal which is set by basepoint snapping would be actually useful to have, especially for duplicating actions - at the moment there is no ability to edit the resulting distance in that direction, it is possible to edit only ortho (axis aligned) distances.
This looks good. Much better than the first iteration. Iâm down for the new system. This looks very helpful, especially with the presets system.
Maybe I missed, are there plans to make asset browserâs bounding-box snapping a general tool? The dev blog at that time said that there are, but I canât find any task from the list or on the project site.
Navigation during transform is such a huge efficiency breaker. Being able to constraint movement just by quickly pressing G and middle mouse button was such a great feature in Blender. Please give us some option to preserve this because it was one of the best features of Blender when modeling or readjusting objects quickly.
As a user who is coming from Maya and Max, being able to do this so fast in Blender was a huge plus. I rarely needed to adjust the camera or rotate viewport while doing these operations, so setting viewport rotation to be priority slows down this workflow dramatically.
Previously, pressing G and quickly pressing MMB was super fast. Now, press G, find ALT key and them MMB, 4-5 times slower to do that operation.
Iâm not a big fan of this change either. Fortunately, it is possible to disable it in the keymap editor/transform modal map. you just have to edit the shortcut and remove alt for the automatic constraints.
Apparently the change of keymaps to allow navigation was not very well seen.
Therefore, the option was brought back.
c0d230e0b80bf5448d37f6949ccf1f44990ad7fc
That is shame. Sadly a lot of workflows in Blender rely on combinations that clash with navigation keymaps, like using middle mouse button for axis constraints, scrolling for influence control (proportional edit, brush size etc). With a well designed keymap this should never have happened, but sadly navigation during transforms wasnât supported initially, so now we have to fight years of habit.
Fortunately only the default is gone, the option to manually toggle it on remains so we can always change, which I certainly will.
Yea, the axis constraint is kind of a dealbreaker for me too. Although I use gizmos more and more⌠but then if youâre using gizmos youâre not using basepoint snapping ! so yes, some work on the keymap is necessary to make it all work together.
I really do hope navigation will be supported during transforms in 4.0. Even with a 3d mouse it was impossible, despite there being no keymap conflicts there.
I agree that user should be able to navigate during transform operation, and yes you can make everything standardized across the application when it comes to shortcuts, but the real question is what the most efficient and faster way of working with Blender and if you are willing to sacrifice that for consistency.
Personally, I started using Blender 3 years ago, I am coming from 14 years of Max and 20+ years of Maya and in those applications things tend to be more consistent. But, when I started using Blender its way of doing stuff, that is not âindustry standardizedâ really opened my eyes of how things can be done in a different and much faster way. These days I barely use Transform gizmo in Blender, like in Max or Maya, I do all the transforms with G R S keys and this works amazing in Blender. Hundreds of times per day also, when I do transforms I lock it to certain axes, and this was so fast by quickly clicking G key and MMB + mouse move to lock to certain axes. It was one of the things that was so good and fast in Blender that no other 3D app could do it in this way. That, amongst other things, was what made me switch to Blender for a lot of modeling tasks I do on daily basis.
I think it is fine for 3D software to be inconsistent regarding shortcuts. I think it is perfectly fine to do thing different than other apps. As long as this makes user workflow more efficient, breaking the rules is good. I do 100 G+MMB axis lock moves per day, I barely do viewport adjustments during that operation because I already adjust viewport to accommodate my transformation. Yes, sometimes you do need to transform 3D view, but in my case that is very rare. So, sacrificing speed for consistency IMHO is a deal breaker and if these changes are coming then we should always give users ability to switch back to the old workflows.
I am actually very glad that other people complained, and they reverted this change.
