When i try to retopo in my blender build 2.8 it crashes sometimes but not when i use the official when from blender builder.
Is there a way to ignore the exception or jump over it without recompile blender?
There is probably a bug here that needs to be fixed.
But it seems you are running a Debug build. You need to set it to Release to get something similar to the official builds, and performance should also be much better then.
how can i decide which version i want to compile? i followed the instructions on the wiki and just go into the blender folder with the console -> make update -> make release to have cuda.
And thanks for the fast answer!
