PROBLEM
- I have a number of objects in my scene, and I want to render one of them.
- I select the object and press Shift-H.
- All objects disappear, including those in collections which have their selection filter disabled.
Usually, if you have a visible object but disabled its selection settings, it’s because you’re done with that object but you want to see it. It should be in the background, or whatever. So, having Shift-H, essentially be no different than local view, feels redundant.
SOLUTION
It would be nice if Shift-H would respect the selection filter in the outliner.
If this interrupts the workflow of others, have it be a toggle setting in the outliner/preferences.
