Hi devs, I wonder why exposing ShaderNodeUVMap.uv_map into a panel converts it to a StringProperty(I can type in or delete string), is this a bug or some kind of limitation? Thank you in advance.
It is a string property, the node UI just uses prop_search
to add the menu and autocomplete.
Ah got it, works fine, thanks @brecht !
