this is my setup:
full path to addon:
E:\blender\shared files between versions\scripts\addons\Screencast-Keys-master\
not listed after restarting blender:
this is my setup:
full path to addon:
That looks like, another, common problem I see pop up over and over in many other places – did you just copy the github repo of that addon?
If so, that’s not going to work; the directory structure in git is different than the directory structure of a proper addon.
You can try to set a BLENDER_USER_SCRIPTS
environment variable - works for me.
you hit the nail on the head, the problem was between the chair and the keyboard Thanks for your help.
thanks, sorted though, it was my fault. I was copying the github root instead of the source folder.
It seems you got it working, but Blender’s way of dealing with file paths in general is a bit… interesting…
It has some design ideas that limit things like Project Managers as in Maya or Houdini to be a very hard to add as a addon or alike.
And just a note here… Try to avoid long foldernames, especially with spaces. Use a _ if neccessary.
Unless the filepath was a example
Hi Jim,
How does one define this in a init startup file, like with Maya’s or Houdini’s .env file?
I have a set of custom application templates running, and if I can add this to the script, it would already make my life a bit simpler
Or even better, use all the File Paths variables for a init startup script.
rob
edit: with the help of the code inside the preferences menu and the application template example I got it to work just fine. It was just getting the proper context in the init file.
In review I’m not sure I understood the question, nor realized purpose of the forum. I’m new to Blender and wanted to get started with Python scripting. I found myself loading Blender defaults a lot and wanted to not have to set the Scripts file path every time I reset. I found that by setting the BLENDER_USER_SCRIPTS
operating system environment variable my test scripts and addons where available no matter which version (stable or nightly) of Blender I opened.
This is the conclusion: If you have a addon zip, the way to install this addon to your custom folder consists of 4 steps:
Install this addon in Blender Perferences window
You will see it install in C:\
, for me it is C:\Users\UserName\AppData\Roaming\Blender Foundation\Blender\3.4\scripts\addons
Set environment variables BLENDER_USER_SCRIPTS = <Your Custom Path>
Cut and paste your addon folder in C:\
to <Your Custom Path>\addons\
Restart Blender and you will see your addon location is right in your custom path and it can be activated without errors like Don't find module xxx
I haven’t tried the environment variable way (I just set it in the Blender preferences), but have you tried just unzipping the addon to your custom folder? That’s all I do, and it automatically shows up in the available addons when refresh. Then it’s just a case of enabling it with the checkbox.
