Running a custom application template with init file from command line/shortcut broken?
HI,
I’ve been looking into custom applications again, but it seems the old issue with init files pops up again for me.
When I run blender with a custom application template from a command line or shortcut, the init.py file that is in the application folder is not run at startup.
It is working when I open the template manually from the splash screen or File menu. I know this has been a issue in the past, and all related threads seem to be set to ‘solved’.
But for my 2.82a & latest 2.83 it is not working as expected from a command line.
Anyone having the same issues on this?
rob
