Do you think is a bad idea to use rsync-like method to compare 2 lists containing library data?
This way should be much more fast because we compare, only in sim mode, two text files.
Let’s say there are some differences between contents, only then the software asks if you want to update the library.
I say this because I noticed it’s extremely slow searching “custom” locations for assets.
