i need to retrieve all filepaths of texture node configured as source “SEQUENCE”.
Currently i am only able to retrieve TextureNode.image.filepath which points to the first texture frame filepath #0001.
I also am able to retrieve every single filepath from an image sequence using bpy.types.ImageUser by modifying the .frame_current value and querying the filepath_from_user(image_user). But, im not able or not seeing the way to perform the opposite operation which would be to set the filepaths of the imagesequence programmatically.
Is there something i am missing?
I tried searching around but no luck.
I also accessed the ImageSequence from bpy.context.sequences but the SequenceElements are empty and the filepath points still to the #0001 first texture frame filepath.
You can find the TextureNode current configuration i am using in the following screenshot.
