Hi all, hope things Blend well.
I’ve just tried to update my repository since the new version 2.8 has been released (had a pull from one of the earlier RCs), and got an error with:
git submodule foreach --recursive git pull --rebase origin master
It enters the blender-translations-submodule and updates those, and then gives me an error:
error: unknown option 'rebase'
usage: git submodule--helper foreach [--quiet] [--recursive] [--] <command>
-q, --quiet Suppress output of entering each submodule command
--recursive Recurse into nested submodules
fatal: run_command returned non-zero status while recursing in the nested submodules of release/datafiles/locale
If I run it again it reports that Already up to date. and that my Current branch master is up to date., but still gives the --rebase error for --recursive…
I’m just starting with git and not sure if I have the full code in place for learning.
Thanks
Neil
p.s. there were no errors with git pull --rebase which I ran prior to the above, in case you’re curious.
