Hello Blender Developers, I have a couple of very important feautures suggestions to improve production pipeline. Rendering Layers overrides and batch mode. In a few words, a system wich allows to set rendering output name, folder, format and options such transparency, frame rate, frame range etc. For each render layer individually and also a way to set the rendering of each render layer in batch mode, so when everything is set up, it’s enough to hit render animation and the system will render each layer in queue with the pre-defined settings.
As it says at the top of the page, this forum is meant for development related topics. For feature requests, please use rightclickselect.com.
