When rendering from the menu a nice little progress bar appears at the base and it can also be cancelled with Esc key.
When i run the process from here:
bpy.ops.render.render(animation=False)
Which is what the docs suggest everything freezes up and i cant cancel wtih Esc key. I know it is still running as i can see the output in both console and folder. Is there a way to have the same behaviour as clicking on the menu item?
Cheers
