Is there a solution to render curve as hair in cylces?
I am trying to import hair animation from other software.It seem perform good when only curves.
If I want to render it, I must convert it to mesh type.
Now with geo nodes(such as Is Viewport node), it is easy.generate curve geometry while render. But with a large numbe of curve, it became very slow. Maybe it can be less cost to generate in render engine?
I wanted that feature as well.
You’ll be able to use alembic cache (animated curves) and render it as hair when this is finished. But this needs a lot of time and work which means it won’t be finished any time soon.
