Is this a bug or am i doing something wrong ?
Test:
Open Blender from the commandline.
Run script that will add a new File Output node, delete the original image name and add a new custom name; then close Blender and the command prompt will kick out “Error: Not freed memory blocks: 1, total unfreed memory”
If i add the File Output node, add a new image name (not touching the original) and then manual delete the original from the Properties panel, Blender closes with out any error.
Also tried newNode.file_slots.clear()
and the same error occurs.
Using Blender 3.5
Heres a quick video to demonstrate.
import bpy
# Error: Not freed memory blocks: 1, total unfreed memory
def addOutputFileNode():
name = "OutTest"
ntree = bpy.context.scene.node_tree
newNode = ntree.nodes.new(type='CompositorNodeOutputFile')
newNode.name = name
newNode.file_slots.remove(newNode.inputs[0])
newNode.file_slots.new("New Image File Name")
return newNode
if __name__ == "__main__":
bpy.context.window.workspace = bpy.data.workspaces['Compositing']
bpy.data.scenes["Scene"].use_nodes = True
addOutputFileNode()
