Short description of error
When trying to build and install blender using unconventional directories, it gives a cmake error:
CMake Error at build-full/source/creator/cmake_install.cmake:2103 (file):
file INSTALL cannot find
"/builds/lmarz/aports/community/blender/src/blender-4.0.0/build-full/source/creator/blender.1":
No such file or directory.
Call Stack (most recent call first):
build-full/cmake_install.cmake:51 (include)
My guess is that it couldn’t find the blender executable to generate the man page and it probably quietly failed until the step where the file is copied to the target directory. Some cmake variables were changed between version 3.6 and 4.0.
Exact steps for others to reproduce the error
Here is the cmake command:
Color management: using fallback mode for management
blf_load_font_default: 'fonts' data path not found for 'Inter.woff2', will not be able to display text
blf_load_font_default: 'fonts' data path not found for 'DejaVuSansMono.woff2', will not be able to display text
Font data directory "fonts/" could not be detected!
Blender 4.0.1 (hash unknown built 2023-11-17 17:59:40)
BLT_lang_init: 'locale' data path for translations not found, continuing
Color management: scene view "AgX" not found, setting default "Standard".
bpy: couldn't find 'scripts/modules', blender probably won't start.
Freestyle: couldn't find 'scripts/freestyle/modules', Freestyle won't work properly.
ModuleNotFoundError: No module named 'bpy_types'
ERROR (bpy.rna): source/blender/python/intern/bpy_rna.cc:7288 pyrna_srna_ExternalType: failed to find 'bpy_types' module
ModuleNotFoundError: No module named 'bpy'
Error: dropbox with unknown operator: WM_OT_drop_blend_file
Error: Python: Traceback (most recent call last):
File "<frozen importlib._bootstrap>", line 1176, in _find_and_load
File "<frozen importlib._bootstrap>", line 1140, in _find_and_load_unlocked
terminate called after throwing an instance of 'std::logic_error'
what(): basic_string: construction from null is not valid
CMake Error at build-full/source/creator/cmake_install.cmake:2093 (file):
"/builds/lmarz/aports/community/blender/src/blender-4.0.1/build-full/source/creator/blender.1":
