Excuse me if this has already been answered, I was going to ask if Viewport Compositing is compatible with EEVEE and Cycles or EEVEE only
Thank you in advance for the answer, and for the work you do and the efforts you put in!
It works with any render engine that supports viewport rendering, including Cycles.
One of the real-time compositor to-do’s is:
“Multi-pass compositing. Needs sizable changes in the draw module and render engines.”
Once this is complete, will the backend foundation be laid for light linking or is that a whole other set of challenges?
Hey Omar, did you work on the Scale Node already?
Hi, it is ready for review already: ⚙ D15758 Realtime Compositor: Implement scale node
Cheers, mib
As far as I know, light linking will be done at the render engine level, so I am not sure why the compositor would be involved.
are there any latest builds that we can play with? I’m interested in the viewport compositor. Is there a difference between the viewport and real-time compositor?
You should read up the blog post
As a first step, this new back-end will be used to power the Viewport Compositor , a new shading option that applies the result of the Compositor Editor node-tree directly in the 3D Viewport. Artists will not have to wait for a full render to start compositing, allowing for faster and more interactive iterations on one’s projects.
The realtime compositor already landed in master as an experimental option. So just download the latest 3.4 build from https://builder.blender.org/. See the blog post for more information.
Heya,
Just trying to run a simple A over B operation using view layers and can’t seem to get it to work.
Is there a trick to this or is this not supported?
Multi-pass and multi-layer compositing is not yet supported.
Do you have any thoughts on how A over B might be achieved?
Object id, Material ID maybe?
When they are supported, sure, they should work just like the existing compositor.
This is just a heads up on A over B comping
The test was link individual objects out to thier own scenes and have all the same objects live in a comp scene. This way I might be able to have the Comp scene A over B or B over A for by reading in different scenes.
The hack workflow didn’t work for me. I think this is because it only reads what’s directly in the current scene, not scenes. I thought that this might work because the compositor can read external images and the current scene.
Not a recommended workflow.
Scenes
Color selection mask
Very Cool, but is there a way to test it already?
I mean, when will it be in a Build or master?
(BTW- is “berlin” just a nickname, or are you also from Berlin? )
It’s already in master. You can download the alpha here: builder.blender.org and test it out. Also see the task on the things that work and the things that won’t ⚓ T99210 Realtime Compositor. The blog post Real-time Compositor — Blender Developers Blog has the instructions on how to use it.
Yeah Thanks, i know-
that RT compositor is already in Master- but my question was specific to the scale node-
That one is (as far as I understand) in review right now- and I don´t know how to find out when a specific Node/patch moves to master…
