Hello everyone
I would like to freely scale an object with a part subtracted using the Boolean Modifier. I notice that scaling all of the objects simultaneously does not work because the boolean object does not scale to the same pivot. Also, when I join the objects together, the Boolean Modifier no longer works.
I spent hours googling for a work around to no avail. Please help me with the issue as stated above.
Thanks for reading.
