I managed to build and use blender as a python module (Blender 2.80 with Python 3.7). However, when rendering a scene with Workbench or Eevee I get the following Python Error:
Process finished with exit code -1073741819 (0xC0000005)
Rendering with Cycles works perfectly. Rendering via Python from within blender works with all engines.
I’m experiencing the same! Blender 2.80, python 3.7 on Ubuntu 18.04, rendering with Workbench or Eevee gives me a Segmentation Fault. Cycles works just fine.
Since I also just tried and successfully build blender as a python module and also came across this: I’m wondering if there’s some documentation about what’s supposed to be possible and what’s not with the blender python module version.
For a practical solution (if this is still relevant for the OP or someone else): Saving a blend file from the python module and then launching a actual blender process works with all rendering engines, here’s an example:
I recently had this issue with Blender as a Python module. The solution consisting in using Blender’s CLI is not suitable if you need to quickly render a lot of images : since it initializes Blender (~5 seconds) you don’t benefit from the rendering speed of Eevee.
I first installed the most recent Blender version (3.5) as a Python module (just follow Blender as a Python module) .
The problem occurs when copying the bin\bpy folder to my python site-packages folder.
