Or I misunderstood what it’s mean?
Docs says that
expand (boolean , ( optional )) – Expand button to show more detail
I used this example
with adding expand=False
parameter and did not notice any changes. I expected to see collapsed button.
Docs says that
I used this example
the expand property of the example and expand argument of the function in the doc is a pure coincidence, they are both named “expand” but meant different usage
the expand argument is meant for properties such as EnumProperty to be expanded in their column or row state
try it out with a Enum prop you will understand the meaning of this argument
So it not possible to make it by default appear collapsed (closed)?
I only can add bpy.context.object.expanded = False
before or after defined function to force state…but it works only after execute function.
Added:
not related for collapsing state but
parameter icon_only=True
and text="Some description here"
do not get along together, text appear on the button independently of icon_only
state.
So if I want other than “expanded” text to be appear by hover mouse on the button I need do some trick?
You just have to set the property with default=False
Oh, understood! Thanks
In registry
bpy.types.Object.expanded = bpy.props.BoolProperty(default=True)
I was looking on this state in prop…
