I’m new here, so please pardon my lack of experience. I’m only allowed two links, so I’ve made footnotes for additional references.
I submitted an issue about the manual pages on Extrude (moved by Iliya Katueshenock from post incorrectly posted at “blender/blender”). The outcome of that appears to be a set of seven edits to the manual. Unfortunately, these changes appear to still be incorrect.
For example:
- in the first edit listed, for “Extrude Edges” [1], the menu selections “Edge ‣ Extrude Edges” and “Mesh ‣ Extrude ‣ Extrude Edges” appear with only a space between them. In the second edit, for “Extrude Faces” [2], the two selections have a comma between them. Presumably those two forms of syntax cannot both be correct. In the manual, these locations should appear in separate button-like text boxes. Will the comma do that? If so, there should be a comma in the first one. If not, they both need to be corrected.
- Several of the edits indicate a keyboard shortcut of “E”. This disagrees with what is indicated in the actual menus in Blender 4.01, which show a shortcut of “E” only for “Extrude Faces”. Unless the actual menus are wrong, the “E” should be removed from those other manual pages.
I would like to make those corrections myself so I can get involved in editing the manual. For that purpose, I’d like to ask the following questions:
- The manual page on editing the manual [3] seems to say that I have to maintain a local copy of the manual on my computer. Is that right, or can I work from online rst files?
- What is the correct syntax when there is more than one menu location? The section of the manual mark-up guide for “Interface Elements” [4] gives the syntax for a menu selection, but not for more than one. Where is the syntax for that documented, or does it just require listing two separate lines of “:menuselection:”?
- Is there a way to know when edits submitted and accepted will appear in the manual online?
Thank you. I look forward to participating in this endeavor.
Footnotes:
[1] first edit listed, for “Extrude Edges”:
projects.blender dot org/blender/blender-manual/src/commit/f5896c878bcc82bb532e2439a990bfc549b45797/manual/modeling/meshes/editing/edge/extrude_edges.rst), the two menu locations
[2] second edit, for “Extrude Faces”:
projects.blender dot org/blender/blender-manual/src/commit/f5896c878bcc82bb532e2439a990bfc549b45797/manual/modeling/meshes/editing/face/extrude_faces.rst
[3] manual page on editing the manual:
docs.blender dot org/manual/en/latest/contribute/editing.html
[4] section of the manual mark-up guide for “Interface Elements”:
docs.blender dot org/manual/en/latest/contribute/guides/markup_guide.html#interface-elements
