Problem with running blender as a python module
Hi
I successfully built blender (2.8) as a python module on manjaro, following instructions here:
but when i try to import bpy in python I get the following error:
Python 3.7.3 (default, Mar 26 2019, 21:43:19)
[GCC 8.2.1 20181127] on linux
Type “help”, “copyright”, “credits” or “license” for more information.
>>> import bpy
File “”, line 1, in
ImportError: /usr/lib/libjemalloc.so.2: cannot allocate memory in static TLS block
can anyone shed some light on this, i’m a bit lost.
thanks.
You can try building with WITH_JEMALLOC=OFF.
thanks brecht
as i’m rather new to this, would this be the correct usage:
sudo make BUILD_CMAKE_ARGS=“-D WITH_JEMALLOC=OFF”
tried this and several other things (make bpy, and disabling WITH_MEM_JEMALLOC), but no dice.
installation runs without errors, files get installed in /usr/lib64/python3.7/site-packages, but as soon as i try to import in python, i get the error:
this is not critical as i’m just playing around with the stuff, but if anyone has any clue …
thanks!
try
cmake -DWITH_JEMALLOC=OFF .
make
in your build folder.
thanks LazyDodo
still the same error.
i started from scratch this time, just to make sure i didn’t mess up something else before.
  • i cloned the blender repository and built blender without any errors, and got a working blender build
  • i then built blender as a python module using make bpy, again without any errors
  • then ran cmake -DWITH_JEMALLOC=OFF . in /build_linux_bpy, which gave me this warning:
CMake Warning:
Manually-specified variables were not used by the project:
WITH_JEMALLOC
  • after running make and make install the problem persisted
  • then tried the same with cmake -DWITH_MEM_JEMALLOC=OFF ., but i’m still getting the same error when i try to import bpy in python
anything else i can try?
thanks
Oops sorry about that, the flag is called WITH_MEM_JEMALLOC .
no worries :wink:
tried that too, but am still getting the same error when importing bpy in python
One thing that worked for me was for:
/home/tibicen/Dokumenty/blender-git/blender/build_files/cmake/config/bpy_module.cmake
to add line (free this line out of if statement):
set(WITH_MEM_JEMALLOC OFF CACHE BOOL "" FORCE)
cause if statement for “Linux” system doesn’t work in all cases. I’m using Fedora 30.
if(CMAKE_SYSTEM_NAME MATCHES "Linux") doesn’t work for me…
Yes, this was my problem on Manjaro:
Once I added set(WITH_MEM_JEMALLOC OFF CACHE BOOL "" FORCE) manually, and re-ran ‘make bpy’, it worked :slight_smile:
Thanks
Just wanted to mention a workaround that doesn’t involve rebuilding without jemalloc support:
LD_PRELOAD=/usr/lib/libjemalloc.so.2 python
