Problem in importing pcl in blender
  • Guys, may be some one can help me with this, I have installed a 3rd party library PCL on Blender than was working correctly then something unclear created this issue:
from ._pcl import *
ImportError: dlopen(/Applications/blender-2.79a/blender.app/Contents/Resources/2.79/python/lib/python3.5/site-packages/pcl/_pcl.cpython-35m-darwin.so, 2): Library not loaded: /usr/local/opt/pcl/lib/libpcl_keypoints.1.9.dylib
Referenced from: /Applications/blender-2.79a/blender.app/Contents/Resources/2.79/python/lib/python3.5/site-packages/pcl/_pcl.cpython-35m-darwin.so
Reason: image not found
  • I tried to check on this dynamic library: /usr/local/opt/pcl/lib/libpcl_keypoints.1.9.dylib , and it does not exist . I found other versions of the dynamic library libpcl_keypoints.1.6 and libpcl_keypoints.1.11 , but the 1.9 is not there, and not able to install it. So i feel so bloecked
so i dunno what to do, specially that when I install the pcl library in blender there is only one way to install it and seems one verrsion from python-pcl library
Guessing by the location /usr/local/opt, was it installed by brew ? Brew could have cleaned it up.
Try reinstalling it.
Thank you so much I will try
