Hi. I need advice on a project I’m hoping to start.
I come from a game development background, where I’ve used Houdini engine to create procedural levels in Unreal and Unity. I’ve also worked for a company that creates models in 3DS Max then exports them to a ThreeJS website.
Introduction
What I’m thinking of is a tool to load Blender objects made with geometry nodes into ThreeJS while keeping the parameters of the geometry nodes intact, so as to be able to adjust those parameters in realtime from within ThreeJS or a running Blender instance.
Houdini engine parallel
Keeping it analogous to Houdini engine, an instance of Blender would be running in the background. The webpage would communicate parameters to this instance which will process these nodes and generate geometry for consumption by ThreeJS.
Bridge mode
An easier way would be to create a Bridge between Blender and ThreeJS, where you could edit meshes in Blender and they would be sent instantly to ThreeJS. This way you would adjust the parameters and mesh in Blender, and see the result reflected in ThreeJS without having to go through exports.
If someone could give me their two cents on this matter I would highly appreciate it.
Here’s a link to the same post I’ve made on the ThreeJS forum if anyone would like to hear from that side: Tool to get Blender procedural geometry to ThreeJS without exporting
