Is storing persistent values (somewhere) while Blender is still open (ie beyond scene scope) possible in Blender, by other means than having python global variables? Something like this
import bpy
bpy.types.WindowManager.session_integer = bpy.props.IntProperty(
name = "I want to keep my value in next scene")
print(bpy.context.window_manager.session_integer)
# 0
bpy.context.window_manager.session_integer += 1
# 1
# Ctrl-N equivalent (File - New)
bpy.ops.wm.read_homefile()
# 0 (should be 1?)
In the code above, last call prints 0, but I’m looking to keep the 1. Is this supported in Blender? If yes, what is the proper way to do it?
there are lots of ways to handle this… you could use a propertygroup and store it with your addon, you could use addonprefs, you could write your variable to a file and read it back, append it to the scene as an attribute, etc.
Storing it on a file would make the data survive beyond the execution of Blender, and appending it to the scene as an attribute does not survive for as long as Blender is open, it will get lost when user changes the scene, but…
@testure this is the one I don’t understand what you mean. Can you please elaborate a bit more, maybe this is what I’m looking for?
If this is a best-practices question, I’d first try avoid the need for this entirely… failing that.
If the logic is local to a class, you could store the value in a class.
Otherwise declare a dictionary, make it’s name explicit global_values or so.
This way you don’t have to declare global when assigning which can be error prone if you ever miss the global declaration.
