Some pixels could be optimized in the Outliner. Especially for smaller screens it would be helpful to have some more space.
PROBLEM
SOLUTION
Thanks.
PROBLEM
SOLUTION
Thanks.
It is not an unused space. The space is for Icons to show which objects are in Edit mode. You can also click the icon to change objects in edit mode.
Also, you can disable it in the filters if it’s a functionality you don’t need.
