Maybe I’m the only one having this, but since the OPTIX requirement has been bumped to 7.3.0 (with Blender 2.9x I believe) the usual make release
calls fail to find the source path of OPTIX. When we were still at 7.2.0 this worked on my system just fine. Error message is:
Could NOT find OptiX (missing: OPTIX_INCLUDE_DIR) (Required is at least version “7.3.0”)
It is clearly installed on my system at default location, when I later on edit CMakeCache.txt
in the root path of the build directory I can use it and build successfully. I just wonder why in the initial project configuration fails to locate it all of a sudden.
I also tried defining an OPTIX_INCLUDE_DIR
environment variable pointing to C:\ProgramData\NVIDIA Corporation\OptiX SDK 7.3.0
but this doesn’t work either.
