Operator properties for each selected object?
Is it possible to have individual operator properties for each selected object? I would like to change several things for each selected object. I don’t know if this is possible ,but haven’t found anything that works.
I have tried something like this. It was suppose to create a bool property for each selected name and if checked show object name.
class ScaleOp(bpy.types.Operator):
	SEL_OBJS = bpy.context.selected_objects
	for OBJECT_SETTINGS in SEL_OBJS:
		 OBJECT_SETTINGS: bpy.props.BoolProperty()
	def draw(self, context):
		layout = self.layout
		col = layout.column()
		for BOOL_OBJECT in SEL_OBJS:
			col.prop(self, "OBJECT_SETTINGS", text=BOOL_OBJECT.name)
			if self.OBJECT_SETTINGS:
				col.label(text=BOOL_OBJECT.name)
OK, I think I’m getting closer ,but still can’t figure this out. I think I need to use a Collection Property. I can draw the settings and they seem independent ,but I can’t execute the settings.
selected_objects_settings
import bpy
class SelectedObjectPanel(bpy.types.Panel):
	bl_label = "Selected Objects"
	bl_space_type = 'VIEW_3D'
	bl_region_type = 'UI'
		col.operator("object.selected_objects", text="Selected Objects")
class SelectedObjectProperties(bpy.types.PropertyGroup):
	SELECTED: bpy.props.BoolProperty()
	OPERATION: bpy.props.EnumProperty(name="Operation",
									   items=(("UNION", "Union", "Use Union"),
											  ("DIFFERENCE", "Difference", "Use Difference"),
											  ("INTERSECT", "Intersect", "Use Intersect")),
									   description="Boolean Operation",
									   default="UNION")
class SelectedObject(bpy.types.Operator):
	bl_idname = "object.selected_objects"
	bl_options = {'REGISTER', 'UNDO'}
	OBJS_COLLECTION: bpy.props.CollectionProperty(type=SelectedObjectProperties)
	def __init__(self):
		self.OBJS_COLLECTION.clear()
		for OBJS in bpy.context.selected_objects:
			ADD_TO_COLLECTION = self.OBJS_COLLECTION.add()
			ADD_TO_COLLECTION.NAME = OBJS.name
		row = layout.row(align=True)
		row.label(text="Objects")
		for OBJS_SEL in self.OBJS_COLLECTION:
			row.prop(OBJS_SEL, "SELECTED", text=OBJS_SEL.NAME)
		col = layout.column(align=True)
		col.label(text="Boolean Operations")
			if OBJS_SEL.SELECTED:
				col.prop(OBJS_SEL, "OPERATION", text=OBJS_SEL.NAME)
	def execute(self, context):
		print(self.OBJS_COLLECTION.OPERATION)
		return {'FINISHED'}
classes = (
	SelectedObjectProperties,
	SelectedObjectPanel,
	SelectedObject
def register():
	from bpy.utils import register_class
	for cls in classes:
		register_class(cls)
def unregister():
	from bpy.utils import unregister_class
	for cls in reversed(classes):
		unregister_class(cls)
if __name__ == "__main__":
	register()
