For most operators the info/values are shown in the top left when you use them.
But for some it appears in the bottom left (at least Bevel and Loop Cut [where it then jumps to the top for the loop slide]).
It’s inconsistent and confusing; you never really know where to look.
Thanks, remembering the issue/problem again.
This is a known issue, developers are trying to solve this. Maybe better ton transfer all the info to the Viewport.
I did suggest you to, take a look at https://developer.blender.org/T57712 it’s very close to you post.
