Hello, this a repost from the [bug report]( #151565 - OneAPI support enabled despite false negative error - blender - Blender Projects ).
This minor bugs shows OneAPI support enabled despite a false negative based on this build extract:
-- Could NOT find SYCL (missing: SYCL_LIBRARY SYCL_INCLUDE_DIR)
-- Found LevelZero: /usr/lib64/libze_loader.so
-- oneAPI not found, disabling WITH_CYCLES_DEVICE_ONEAPI
-- SYCL 6.0+ or Level Zero not found, disabling WITH_CYCLES_DEVICE_ONEAPI
Yet,
Rendering (Cycles):
- WITH_CYCLES_OSL ON
- WITH_CYCLES_EMBREE ON
- WITH_CYCLES_PATH_GUIDING ON
- WITH_CYCLES_DEVICE_OPTIX ON
- WITH_CYCLES_DEVICE_CUDA ON
- WITH_CYCLES_CUDA_BINARIES OFF
- WITH_CYCLES_DEVICE_ONEAPI ON
- WITH_CYCLES_ONEAPI_BINARIES ON
- WITH_CYCLES_DEVICE_HIP ON
- WITH_CYCLES_HIP_BINARIES ON
- WITH_CYCLES_DEVICE_HIPRT ON
Reference from the Blender spec file on Fedora source build system. OneAPI Level Zero is available as dependency hence -- Found LevelZero: /usr/lib64/libze_loader.so bringing a confusion with this line: -- SYCL 6.0+ or Level Zero not found, disabling WITH_CYCLES_DEVICE_ONEAPI . If SYCL is the actual missing component for WITH_CYCLES_DEVICE_ONEAPI=ON, then Level Zero should not be mentioned.
