- At the moment is very difficult to make connections while zoomed out without accidentaly dragging the whole node. Nodes far apart require that you stay zoomed out to see the both ends of a connection.
- Complicated connections make difficult to identify the other end of a connection line and the current highlight style is not so clear.
- I want to propose having the nodes sockets about 3x the current size. And maybe to resize/contour highlight them dynamically on mouse over.
- The connection lines will be more visible if the actual color of the line will change on mouse over either end socket.
In some situations triggering auto panning on window border proximity while dragging a node selection or a connection line would be a helpful addition.
Thanks!
