Hello,
I was wondering if there is a user interface specification available specifically for the node editors. I am working on an add-on to export node graphs to SVG for technical reports, and while I could try to intuit the various dimensions and font sizes and corner rounding from a screenshot, I wanted to ask if such information is documented somewhere. I have looked through the source code and found some functions for drawing the node graphs, but other than Bezier control point specifications, they lacked the details I am looking for.
Also it could help with how a node fits into the dimensions window. For example here, I have used the two node objects’ location
and dimensions
attributes (from bpy
) and rendered two rectangles with them. It’s clear that the ‘bounding boxes’ of each node stretch beyond the rounded box, and seems to extend a bit further to the right, too?
Thank you
