move cursor under mouse clic and with selections:
so you can insert text everywhere overwrite a selection
same with ctrl x, ctrl v, suppr, backspace
ctrl A select line, shift+right/left arrow to translate selection
Now an undo Ctrl+Z and a redo shift+ctrl+Z in the console!
add ctrl Q: quick favorite
This is awesome! Why not submit it as a patch to be integrated into master?
I don’t know how to do
https://wiki.blender.org/wiki/Process/Contributing_Code
The change doesn’t seem to be large enough for an add-on, so the source code is at release/scripts/startup/bl_ui/space_console.py
& source/blender/editors/space_console/console_ops.c
Upload a patch, keep improving it using arcanist [1] & add a reviewer.
Feel free to ask for help at https://blender.chat
ok thks I will watch this
I added a Ctrl V to paste over a selection if exists. and same to cut a selection
writing on a selected word is writing at the end of the word where the cursor is, by default.
but I did a script to write over selection too but I can’t do bpy.ops.console.insert(‘INVOKE_DEFAULT’)
in the C file related to console operators they are telling they only considered the situation or the invoke would be called from a key and not from a script. Apparently not a bug but I don’t know where to ask. really accessing this part is like a wall for me
For the record, I just commented out the bpy.ops.console.insert('INVOKE_DEFAULT')
lines and replaced the return value with {'PASS_THROUGH'}
and it worked.
class CONSOLE_OT_Insert(bpy.types.Operator):
"""insert"""
bl_idname = "console.easy_insert"
bl_label = "console easy insert"
@classmethod
def poll(cls, context):
return context.area.type == 'CONSOLE'
def execute(self, context):
sc = context.space_data
st, se = (sc.select_start, sc.select_end)
if st == se:
# bpy.ops.console.insert('INVOKE_DEFAULT')
print("no")
pass
else:
print("hi")
for _ in range(se-st):
bpy.ops.console.move(type='LINE_END')
for _ in range(st):
bpy.ops.console.move(type='PREVIOUS_CHARACTER')
bpy.ops.console.delete(type='PREVIOUS_CHARACTER')
sc.select_start = st
sc.select_end = st
return {'PASS_THROUGH'}
I fixed paste
added translate selection |shift+left/right arrow|
menus entries
[https://github.com/1C0D/console_easy_text_edit-Blender ]
