I’m focusing on a multiple obj import and need to strenghten a bit the routine you published.
The idea is:
Import OBJ recursively scanning on multiple subfolders, ONE by ONE
Apply Lily Texture Packer Plugin for each object imported and link to newly created material
Delete any other unused material
Save Lily Textured file .png in the same folder
Export a new FBX into the native folder
(I saw that the tiles imported are shrinking from 500mb to 60mb, doing by hand, and it would be useful for massive import, i’m on 200 tiles at the moment).
import bpy
import os
import sys
from bpy_extras.io_utils import ImportHelper
from bpy.props import (BoolProperty,
FloatProperty,
StringProperty,
EnumProperty,
CollectionProperty
import glob
bpy.ops.outliner.orphans_purge()
directory_im = './3042726071604147-20-894/'
files = glob.glob(directory_im + "*.obj")
# helper method to create a new LayerCollection
# also setting it to the active LayerCollection
# the Google Maps importer then puts the objects into that LayerCollection automatically
def create_coll(parent_layer_collection, collection_name):
new_col = bpy.data.collections.new(collection_name)
parent_layer_collection.collection.children.link(new_col)
new_child_layer_coll = parent_layer_collection.children[new_col.name]
bpy.context.view_layer.active_layer_collection = new_child_layer_coll
return new_child_layer_coll
# create a master collection to batch import the files to, or re-use the currently active collection in the
scene - up to you
master_collection = bpy.context.view_layer.active_layer_collection
# iterate over files
for f in files:
head, tail = os.path.split(f)
collection_name = tail.replace('.obj', '')
# create a new LayerCollection to import the objects to
# I am toring the reference to it here in case you need to run further actions on it
# e.g. changing color etc etc
myCol = create_coll(master_collection, collection_name)
# run the importer, it will work within the new sub-collection
#bpy.ops.import_rdc.google_maps(filepath=(f), filter_glob=".rdc", max_blocks=-1)
bpy.ops.import_scene.obj(filepath=f, filter_glob="*.obj;*.mtl", use_image_search=True, axis_forward='-Z', axis_up='Y')
bpy.ops.object.lily_texture_packer(spacing=0)
obj_object = bpy.context.selected_objects[0] ####<--Fix
#for SlcObj in obj_select:
# bpy.ops.object.material_slot_select(mat)
# bpy.ops.object.make_links_data(type='Material')
ob = bpy.context.active_object
# Get material
mat = bpy.data.materials.get("Material")
if mat is None:
# create material
mat = bpy.data.materials.new(name="Material")
# Assign it to object
if ob.data.materials:
# assign to 1st material slot
ob.data.materials[0] = mat
else:
# no slots
ob.data.materials.append(mat)
print('Imported Collection: ', obj_object.name)
# bpy.ops.export_scene.fbx(bpy.ops.export_scene.fbx(filepath=...)
