- Enter outliner, click something, then move up and down with arrow keys.
- Apparently only //selected// object is changed, not //active// object, because a whole bunch of behavior (which object gets edited if you press TAB in viewport, which object’s properties are visible in property window) does not change as expected.
Solution:
- Make the arrow keys in the outliner update the selected object AND the active object
