I have used the Operator Modal Timer template to make two different modal timers. One fires every second, the other every five seconds. When the second ‘TIMER’ event type fires, so does the first one.
Is it possible to determine which of the two timers fired the ‘TIMER’ event type?
edit - I noticed in the API documentation https://docs.blender.org/api/master/bpy.types.Event.html?highlight=modal%20timer there are also events for ‘TIMER 0’ and ‘TIMER 1’ etc. What are these used for?
import bpy
class ModalTimerOperator1(bpy.types.Operator):
"""Operator which runs its self from a timer"""
bl_idname = "wm.modal_timer_operator_1"
bl_label = "Modal Timer Operator 1"
_timer = None
def modal(self, context, event):
if event.type in {'RIGHTMOUSE', 'ESC'}:
self.cancel(context)
return {'CANCELLED'}
if event.type == 'TIMER':
# This timer event gets triggered from wm.modal_timer_operator_2
print("event timer")
return {'PASS_THROUGH'}
def execute(self, context):
wm = context.window_manager
self._timer = wm.event_timer_add(1.0, window=context.window)
wm.modal_handler_add(self)
return {'RUNNING_MODAL'}
def cancel(self, context):
wm.event_timer_remove(self._timer)
class ModalTimerOperator2(bpy.types.Operator):
bl_idname = "wm.modal_timer_operator_2"
bl_label = "Modal Timer Operator 2"
_timer = None
pass
self._timer = wm.event_timer_add(5.0, window=context.window)
def register():
bpy.utils.register_class(ModalTimerOperator1)
bpy.utils.register_class(ModalTimerOperator2)
def unregister():
bpy.utils.unregister_class(ModalTimerOperator2)
bpy.utils.unregister_class(ModalTimerOperator1)
if __name__ == "__main__":
register()
