Is there any way to get the mouse position on the Grid view?
The “region_2d_to_location_3d” return a position that is parallel with view.
but i need a position like [x, y, 0]
Im working on an add-on for simulate 3Ds Max interface in Blender. in 3Ds Max every thing create on floor(grid) but for now Im not able to make the object on exact clicked point.
I wrote this script and I added comments to most of the lines to be easier to understand.
You can just place it in the script editor and start it. Then press F3 and search for “Get position on the grid”.
Run it and it should place an empty on the grid under the mouse cursor.
from bpy.types import Operator
import mathutils
from mathutils import Vector
from bpy_extras import view3d_utils
class GetPositionOnGrid(Operator):
"""Get a 3D position on the grid based on mouse cursor position"""
bl_idname = "nevil.get_position_on_grid"
bl_label = "Get position on the grid"
# This function is just for testing
def create_test_empty(self, context):
'''Create an empty, link it to the scene and show the axis'''
if bpy.data.objects.get("TestEmpty"):
bpy.data.objects.remove(bpy.data.objects["TestEmpty"], do_unlink = True)
manipulator_empty = bpy.data.objects.new("TestEmpty", None)
scene_collection = context.layer_collection.collection
scene_collection.objects.link(manipulator_empty)
manipulator_empty.show_axis = True
return manipulator_empty
def invoke (self, context, event):
viewport_region = context.region
viewport_region_data = context.space_data.region_3d
viewport_matrix = viewport_region_data.view_matrix.inverted()
# Shooting a ray from the camera, through the mouse cursor towards the grid with a length of 100000
# If the camera is more than 100000 units away from the grid it won't detect a point
ray_start = viewport_matrix.to_translation()
ray_depth = viewport_matrix @ Vector((0,0,-100000))
# Get the 3D vector position of the mouse
ray_end = view3d_utils.region_2d_to_location_3d(viewport_region,viewport_region_data, (event.mouse_region_x, event.mouse_region_y), ray_depth )
# A triangle on the grid plane. We use these 3 points to define a plane on the grid
point_1 = Vector((0,0,0))
point_2 = Vector((0,1,0))
point_3 = Vector((1,0,0))
# Create a 3D position on the grid under the mouse cursor using the triangle as a grid plane
# and the ray cast from the camera
position_on_grid = mathutils.geometry.intersect_ray_tri(point_1,point_2,point_3,ray_end,ray_start,False )
# Create an empty for testing
empty = self.create_test_empty(context)
# Place the empty on the grid under the mouse cursor
empty.location = position_on_grid
return {'FINISHED'}
classes = (
GetPositionOnGrid,
register, unregister = bpy.utils.register_classes_factory(classes)
if __name__ == "__main__":
register()
Your add-on looks very nice btw!
Thank you Oskar, this is clear and understandable and working perfectly. I update the function and result is perfect now.
You’re welcome! I’m glad it worked!
I was trying to do something similar last week and I had part of it done.
Thanks a lot for this very useful function! I was wondering if this solution can be made to work in orthographic view as well. Looks like, in its current implementation, it works only for perspective view.
An interesting idea. I will follow the addon. It will be great if all the functions work like in max.
Hi Khemadeva
I have update this code to work on other views too. you can download BsMax and get the function from
“BsMax_2_80/Primitive/Primitive.py” search for “get_click_point_info(x, y, ctx)”
Codes are a little ugly
but works for now. I`ll clean them up soon as possible
Thank you Ghostil
I try to do my best, but I need support for report bugs and give me ideas to improve better. and share it, to other people interested and need it be able to find it easy.
