User Interface Meeting Notes
Present: Campbell Barton, Hans Goudey, Harley Acheson, Julian Eisel, Pablo Vazquez
Announcements
- Updated module page and navigation-bar: Developer Portal - developer.blender.org
Organization
- Usability workshop
- It’s not clear what the purpose/scope is yet.
- Planning is done by the BI, the UI module is not involved currently.
- This makes it hard for the team to plan ahead.
- Julian wants to clear things up next week.
- Expectations have to be managed given the amount of time developers can allocate to potential UI projects.
- There are a few important patches waiting for final approval.
- Technical debt in UI code is a burden
- The module can continue code quality days on the first Friday of every month.
- Some low-hanging fruits go a long way (E.g. inheritance based UI button types, basic use of C++, etc.).
- The recent porting of Outliner code to a new (C++ based) design seems like a good direction, similar patterns can be applied elsewhere.
- Keymap cleanup: de-duplicate tweak/click-drag, remove internal operators from keymap (action zones, animation timers, etc.).
General Design Review and Tasks
Harley’s list of patches:
- Reconfirmed: The camera lock design should be revisited, since it was quite popular.
- A takeaway from that situation: The more visible a change is, the more it needs to be reviewed by stakeholders, etc.
- Improved area maintenance: Join or Close any area.
- Generally this is quite close and the team is happy with the patch.
- Pablo will check the visual side of it
- Maybe disable merging unrelated areas (areas you didn’t start the dragging from)?
- Improved Blend thumbnails
- Double check performance isn’t an issue on large (e.g. 8k) windows.
- This should be an option, since render thumbnails are quite important in some situations
- The “No Thumbnail”, “Render”, “UI” option can become an enum
- Besides that, there should be a final check with artists before changing the default.
- A File Loading Dialog
- The popup could use some layout changes
- There are some technical questions, but in general flicker in rare situations is likely unavoidable.
- Set current installation as default Blender
- This can move to the system menu
- The system menu could possible be relocated in a separate patch
- Is this mainly needed for the steam installer? Investigate if the steam installer could handle this.
- Nicer Operator Confirm Dialog
- This can be used for changes that could cause data loss, rather than regular confirmations like “Delete Object”
- Window Title Format
- Part of the change with the asterisk could be split out as a fix
- But in general the team doesn’t agree with having the version in the header.
