Hi
I’ve built the source code using CMAKE and am running the executable out of /home/brent/blender-git/build/bin
Where are the outputs from BKE_reportf going to end up?
BKE_reportf(
reports, RPT_INFO, "Object '%s' already has a Rigid Body Constraint", ob->id.name + 2);
Thanks
I feel qualified to talk about it
(my GSoC is about logging & reporting)
In master:
- if you are in background mode, reports will be written to console
- in general reports can be viewed in info editor
– memory is owned by wmWindowManager, info editor operates directly on this struct, but
– in various locations in code you can create your own copies of ReportList which end up god knows where
– if ReportList has a flag RPT_PRINT it will be printed
– if ReportList has flag RPT_STORE it will be stored (and visible in info editor)
note, Log in strict meaning is different from Report (see CLOG_INFO), but currently it is a bit messy, I am making big changes to reports and logs on My branch named soc-2020-info-editor (pretty unstable at a time, write if you need help starting it).
