I’ve searched everywhere I know, I couldn’t find how to list all the selected components (be it vertices, edges or faces) while in multi-object editing. All my attempts could only list those of the active object.
Note: going in and out of edit mode for each selected object is not an option for me, as it would be too slow.
bms = {}
for o in context.objects_in_mode:
if not hasattr(o, "data"):
continue
bm[o] = bmesh.from_edit_object(o.data)
# then later on
for o in bms:
for v in bms[o].verts:
print(f"{o.name} - {v.index}, {v.co}")
you don’t have to store the bmesh objects in a dictionary, you could do whatever you need to do in that first loop- but I find that it’s convenient to do it this way, especially if you’re writing a modal operator.
Thanks.
I can’t get a printed list though. If I’m in edit mode, I get an
AttributeError: module 'bmesh' has no attribute 'from_edit_object'
and in object mode I get nothing at all.
from_edit_object
returns no search result in the API
Sorry, should be from_edit_mesh, I did that from memory on my phone
Thank you!
I made some changes and the following snippet makes a dictionary where keys are the object paths and their respective values are the indices of their selected vertices:
import bpy
import bmesh
dic_v = {}
for o in bpy.context.objects_in_mode:
dic_v.update( {o : []} )
bm = bmesh.from_edit_mesh(o.data)
for v in bm.verts:
if v.select:
dic_v[o].append(v.index)
print(dic_v)
