Hi there,
tried to build the master branch, Release 64 bit on Windows 10 ,VS2017.
Failed on building INSTALL project:
Severity Code Description Project File Line Suppression State
Error LNK2019 unresolved external symbol “__declspec(dllimport) public: static class std::basic_string<char,struct std::char_traits,class std::allocator > __cdecl openvdb::v7_0::io::DelayedLoadMetadata::staticTypeName(void)” (_imp?staticTypeName@DelayedLoadMetadata@io@v7_0@openvdb@@SA?AV?$basic_string@DU?$char_traits@D@std@@V?$allocator@D@2@@std@@XZ) referenced in function “public: class std::shared_ptr __cdecl openvdb::v7_0::MetaMap::getMetadata(class std::basic_string<char,struct std::char_traits,class std::allocator > const &)” (??$getMetadata@VDelayedLoadMetadata@io@v7_0@openvdb@@@MetaMap@v7_0@openvdb@@QEAA?AV?$shared_ptr@VDelayedLoadMetadata@io@v7_0@openvdb@@@std@@AEBV?$basic_string@DU?$char_traits@D@std@@V?$allocator@D@2@@4@@Z) blender D:\Projekte\Blender\Blender-283\build_windows_Full_x64_vc15_Release\source\creator\bf_intern_mantaflow.lib(MANTA_main.obj) 1
Also error for cmake:
Error MSB3073 The command “setlocal
“C:\Program Files\CMake\bin\cmake.exe” -DBUILD_TYPE=Release -P cmake_install.cmake
if %errorlevel% neq 0 goto :cmEnd
:cmEnd
endlocal & call :cmErrorLevel %errorlevel% & goto :cmDone
:cmErrorLevel
exit /b %1
:cmDone
if %errorlevel% neq 0 goto :VCEnd
:VCEnd” exited with code 1. INSTALL C:\Program Files (x86)\Microsoft Visual Studio\2017\Community\Common7\IDE\VC\VCTargets\Microsoft.CppCommon.targets 138
Any hints?
Bye
Jay
