trying to build lanpr-under-gp branch on OSX will end outputting 2 errors either you compile it with cmake or Xcode.
cmake outputs:
[ 10%] Building CXX object extern/mantaflow/CMakeFiles/extern_mantaflow.dir/preprocessed/commonkernels.h.reg.cpp.o
/Users/ivan/blender-git/blender/extern/glog/src/utilities.cc:262:17: warning:
'syscall' is deprecated: first deprecated in macOS 10.12 - syscall(2) is
unsupported; please switch to a supported interface. For SYS_kdebug_trace
use kdebug_signpost(). [-Wdeprecated-declarations]
pid_t tid = syscall(__NR_gettid);
/Applications/Xcode.app/Contents/Developer/Platforms/MacOSX.platform/Developer/SDKs/MacOSX10.15.sdk/usr/include/unistd.h:742:6: note:
'syscall' has been explicitly marked deprecated here
int syscall(int, ...);
[ 17%] Building CXX object extern/ceres/CMakeFiles/extern_ceres.dir/internal/ceres/context.cc.o
/Users/ivan/blender-git/blender/source/blender/editors/gpencil/gpencil_add_lineart.c:97:63: warning:
unused parameter 'mat' [-Wunused-parameter]
void ED_gpencil_create_lineart(bContext *C, Object *ob, float mat[4][4])
1 warning generated.
[ 22%] Building CXX object extern/ceres/CMakeFiles/extern_ceres.dir/internal/ceres/evaluator.cc.o
/Users/ivan/blender-git/blender/source/blender/editors/object/object_add.c:1389:35: warning:
initializing 'EnumPropertyItem *' (aka 'struct EnumPropertyItem *') with
an expression of type 'const EnumPropertyItem []' discards qualifiers
[-Wincompatible-pointer-types-discards-qualifiers]
EnumPropertyItem *item = NULL, *item_ref = rna_enum_object_gpencil_type_items;
/Users/ivan/blender-git/blender/source/blender/editors/object/object_add.c:1384:25: warning:
no previous prototype for function 'object_gpencil_add_options'
[-Wmissing-prototypes]
const EnumPropertyItem *object_gpencil_add_options(bContext *C,
/Users/ivan/blender-git/blender/source/blender/editors/object/object_add.c:1384:7: note:
declare 'static' if the function is not intended to be used outside of
this translation unit
static
[ 29%] Building C object source/blender/editors/space_info/CMakeFiles/bf_editor_space_info.dir/info_stats.c.o
In file included from /blender-git/blender/source/blender/editors/space_file/fsmenu.c:56:
In file included from /Applications/Xcode.app/Contents/Developer/Platforms/MacOSX.platform/Developer/SDKs/MacOSX10.15.sdk/System/Library/Frameworks/Carbon.framework/Headers/Carbon.h:20:
In file included from /Applications/Xcode.app/Contents/Developer/Platforms/MacOSX.platform/Developer/SDKs/MacOSX10.15.sdk/System/Library/Frameworks/CoreServices.framework/Headers/CoreServices.h:23:
In file included from /Applications/Xcode.app/Contents/Developer/Platforms/MacOSX.platform/Developer/SDKs/MacOSX10.15.sdk/System/Library/Frameworks/CoreServices.framework/Frameworks/AE.framework/Headers/AE.h:20:
In file included from /Applications/Xcode.app/Contents/Developer/Platforms/MacOSX.platform/Developer/SDKs/MacOSX10.15.sdk/System/Library/Frameworks/CoreServices.framework/Frameworks/CarbonCore.framework/Headers/CarbonCore.h:51:
/Applications/Xcode.app/Contents/Developer/Platforms/MacOSX.platform/Developer/SDKs/MacOSX10.15.sdk/System/Library/Frameworks/CoreServices.framework/Frameworks/CarbonCore.framework/Headers/Collections.h:138:41: error:
typedef redefinition with different types ('struct OpaqueCollection *' vs
'struct Collection')
typedef struct OpaqueCollection* Collection;
/blender-git/blender/source/blender/makesdna/DNA_collection_types.h:91:3: note:
previous definition is here
} Collection;
Xcode debugger outputs:
bf_editor_object
Semantic Issue
/blender-git/blender/source/blender/editors/object/object_add.c:1389:35: Initializing 'EnumPropertyItem *' (aka 'struct EnumPropertyItem *') with an expression of type 'const EnumPropertyItem []' discards qualifiers
/blender-git/blender/source/blender/editors/object/object_add.c:1384:25: No previous prototype for function 'object_gpencil_add_options'
/blender-git/blender/source/blender/editors/object/object_add.c:1384:7: Declare 'static' if the function is not intended to be used outside of this translation unit
bf_editor_space_file
Semantic Issue
/Applications/Xcode.app/Contents/Developer/Platforms/MacOSX.platform/Developer/SDKs/MacOSX10.15.sdk/System/Library/Frameworks/CoreServices.framework/Frameworks/CarbonCore.framework/Headers/Collections.h:138:41: Typedef redefinition with different types ('struct OpaqueCollection *' vs 'struct Collection')
/blender-git/blender/source/blender/editors/space_file/fsmenu.c:56:12: In file included from /blender-git/blender/source/blender/editors/space_file/fsmenu.c:56:
/Applications/Xcode.app/Contents/Developer/Platforms/MacOSX.platform/Developer/SDKs/MacOSX10.15.sdk/System/Library/Frameworks/Carbon.framework/Headers/Carbon.h:20:10: In file included from /Applications/Xcode.app/Contents/Developer/Platforms/MacOSX.platform/Developer/SDKs/MacOSX10.15.sdk/System/Library/Frameworks/Carbon.framework/Headers/Carbon.h:20:
/Applications/Xcode.app/Contents/Developer/Platforms/MacOSX.platform/Developer/SDKs/MacOSX10.15.sdk/System/Library/Frameworks/CoreServices.framework/Headers/CoreServices.h:23:10: In file included from /Applications/Xcode.app/Contents/Developer/Platforms/MacOSX.platform/Developer/SDKs/MacOSX10.15.sdk/System/Library/Frameworks/CoreServices.framework/Headers/CoreServices.h:23:
/Applications/Xcode.app/Contents/Developer/Platforms/MacOSX.platform/Developer/SDKs/MacOSX10.15.sdk/System/Library/Frameworks/CoreServices.framework/Frameworks/AE.framework/Headers/AE.h:20:10: In file included from /Applications/Xcode.app/Contents/Developer/Platforms/MacOSX.platform/Developer/SDKs/MacOSX10.15.sdk/System/Library/Frameworks/CoreServices.framework/Frameworks/AE.framework/Headers/AE.h:20:
/Applications/Xcode.app/Contents/Developer/Platforms/MacOSX.platform/Developer/SDKs/MacOSX10.15.sdk/System/Library/Frameworks/CoreServices.framework/Frameworks/CarbonCore.framework/Headers/CarbonCore.h:51:10: In file included from /Applications/Xcode.app/Contents/Developer/Platforms/MacOSX.platform/Developer/SDKs/MacOSX10.15.sdk/System/Library/Frameworks/CoreServices.framework/Frameworks/CarbonCore.framework/Headers/CarbonCore.h:51:
/blender-git/blender/source/blender/makesdna/DNA_collection_types.h:91:3: Previous definition is here
datatoc_icon
Apple Mach-O Linker (ld) Warning
: Directory not found for option '-L/blender-git/blender/../lib/darwin/png/lib/Debug'
extern_glog
Deprecations
/blender-git/blender/extern/glog/src/raw_logging.cc:139:3: 'syscall' is deprecated: first deprecated in macOS 10.12 - syscall(2) is unsupported; please switch to a supported interface. For SYS_kdebug_trace use kdebug_signpost().
/blender-git/blender/extern/glog/src/raw_logging.cc:63:34: Expanded from macro 'safe_write'
/Applications/Xcode.app/Contents/Developer/Platforms/MacOSX.platform/Developer/SDKs/MacOSX10.15.sdk/usr/include/unistd.h:742:6: 'syscall' has been explicitly marked deprecated here
/blender-git/blender/extern/glog/src/utilities.cc:262:17: 'syscall' is deprecated: first deprecated in macOS 10.12 - syscall(2) is unsupported; please switch to a supported interface. For SYS_kdebug_trace use kdebug_signpost().
bf_intern_ghost
Deprecations
/blender-git/blender/intern/ghost/intern/GHOST_ContextCGL.mm:233:23: 'NSOpenGLPFAStereo' is deprecated: first deprecated in macOS 10.12
/Applications/Xcode.app/Contents/Developer/Platforms/MacOSX.platform/Developer/SDKs/MacOSX10.15.sdk/System/Library/Frameworks/AppKit.framework/Headers/NSOpenGL.h:89:5: 'NSOpenGLPFAStereo' has been explicitly marked deprecated here
/blender-git/blender/intern/ghost/intern/GHOST_WindowCocoa.mm:407:16: 'setAcceptsTouchEvents:' is deprecated: first deprecated in macOS 10.12.2 - Use allowedTouchTypes instead
/Applications/Xcode.app/Contents/Developer/Platforms/MacOSX.platform/Developer/SDKs/MacOSX10.15.sdk/System/Library/Frameworks/AppKit.framework/Headers/NSView.h:227:16: Property 'acceptsTouchEvents' is declared deprecated here
/Applications/Xcode.app/Contents/Developer/Platforms/MacOSX.platform/Developer/SDKs/MacOSX10.15.sdk/System/Library/Frameworks/AppKit.framework/Headers/NSView.h:227:16: 'setAcceptsTouchEvents:' has been explicitly marked deprecated here
bf_editor_gpencil
Semantic Issue
/blender-git/blender/source/blender/editors/gpencil/gpencil_add_lineart.c:97:63: Unused parameter 'mat'
