I primarily use Linux. Using Blender on Linux (installed from my distro’s repositories), I can go to the console and import PIL no problem.
If I hop over to Windows and try to do the same thing (Blender downloaded from Blender.org), I’m hit with “No module named PIL”.
My understanding (which might be wrong) is that Blender includes its own Python install. As such… should this not be consistent? Regardless of where you got Blender?
I think the only python libraries that are bundled in the official releases are numpy and requests.
So I’m guessing that your linux dist are not bundling python and instead uses the system wide install, which you can choose to do when compiling blender.
You can check which module is actually used with e.g. this:
# Official binaries
# Numpy is included, note the path to numpy/__init__.py
melis@juggle 12:14:~/software/blender-2.92.0-linux64$ ./blender -b --python-expr 'import numpy; print(numpy.__file__)'
Blender 2.92.0 (hash 02948a2cab44 built 2021-02-25 09:31:37)
Read prefs: /home/melis/.config/blender/2.92/config/userpref.blend
loading in background
/home/melis/software/blender-2.92.0-linux64/2.92/python/lib/python3.7/site-packages/numpy/__init__.py
Blender quit
# PIL is not included in the official Blender distro and cannot be found
melis@juggle 12:14:~/software/blender-2.92.0-linux64$ ./blender -b --python-expr 'import PIL; print(PIL.__file__)'
<bpy_struct, WindowManager("WinMan") at 0x7f0f4cb05c08>
Error: Python: Traceback (most recent call last):
File "<string>", line 1, in <module>
ModuleNotFoundError: No module named 'PIL'
My Arch linux blender package can find all system-wide packages, e.g.:
# PIL can now be found
melis@juggle 12:17:~$ /usr/bin/blender -b --python-expr 'import PIL; print(PIL.__file__)'
Blender 2.92.0 (hash 02948a2cab44 built 2021-04-25 11:39:34)
<bpy_struct, WindowManager("WinMan") at 0x7febdcbd5008>
/usr/lib/python3.9/site-packages/PIL/__init__.py
Blender quit
# Even system-wide numpy is used
melis@juggle 12:17:~$ /usr/bin/blender -b --python-expr 'import numpy; print(numpy.__file__)'
<bpy_struct, WindowManager("WinMan") at 0x7f1b911e3008>
/usr/lib/python3.9/site-packages/numpy/__init__.py
Blender quit
Even with the official binaries it’s possible to use sys.path to point to the right system-wide location:
However, this might open a can of worms in terms of version compatibility between Blender’s builtin Python interpreter and the system-wide one, especially for packages that contain compiled C code like numpy.
