hi everyone,
is it possible to show only the OK button in invoke_props_dialog dialog? currently by default, it shows OK and CANCEL, but in earlier versions, it used to show only the OK button!
Generally we prefer to have both a confirm and cancel button, but for special occasions this will probably help you:
thank you @Harleya !
I do not know what I am doing wrong, but if I pass empty string to the function template_popup_confirm
as the operator, I get the default behavior (two buttons) .
If I pass bl_idname of the same class, I get the desired UI, but infinite loop of dialogs if I keep pressing the OK button.
any suggestions?
btw, the code I am editing is part of the MustardSimplify addon :
import bpy
class MUSTARDSIMPLIFY_OT_MenuBlenderSimplifySettings(bpy.types.Operator):
"""Modify Blender Simplify settings"""
bl_idname = "mustard_simplify.menu_blender_simplify_settings"
bl_label = "Blender Simplify Settings"
@classmethod
def poll(cls, context):
return True
def execute(self, context):
return {'FINISHED'}
return context.window_manager.invoke_props_dialog(self, width=400)
def draw(self, context):
scene = context.scene
layout = self.layout
layout.use_property_split = True
rd = scene.render
box = layout.box()
box.label(text="Viewport", icon="RESTRICT_VIEW_ON")
flow = box.grid_flow(row_major=True, columns=0, even_columns=False, even_rows=False, align=True)
col = flow.column()
col.prop(rd, "simplify_subdivision", text="Max Subdivision")
col = flow.column()
col.prop(rd, "simplify_child_particles", text="Max Child Particles")
col = flow.column()
col.prop(rd, "simplify_volumes", text="Volume Resolution")
col = flow.column()
col.prop(rd, "use_simplify_normals", text="Normals")
box = layout.box()
box.label(text="Render", icon="RESTRICT_RENDER_ON")
col = flow.column()
col.prop(rd, "simplify_subdivision_render", text="Max Subdivision")
col = flow.column()
col.prop(rd, "simplify_child_particles_render", text="Max Child Particles")
# MY ADDED CODE IS THE NEXT LINE
layout.template_popup_confirm("", text="Okkey!", cancel_text="")
def register():
bpy.utils.register_class(MUSTARDSIMPLIFY_OT_MenuBlenderSimplifySettings)
def unregister():
bpy.utils.unregister_class(MUSTARDSIMPLIFY_OT_MenuBlenderSimplifySettings)
the last line of the draw method is my edition!
I haven’t explored that template_popup_confirm
very much, mostly just testing it to see that it worked.
What it the use case though? Are you wanting a purely informational “info”-style popup to inform the user of something and then just have them dismiss with an “okay”? Or does the confirm really do something and you just wanting to remove the cancel for some reason? Does the operation not have an applicable cancel?
I edited the previous reply!
actually the code change simplify settings on the fly inside a modal, so here cancel is just misleading since it does not cancel the changes.
