Hello!
I am a blender noob, coming from a long career as a Maya TD who wears many hats. I really like how far blender has come and am generally enjoying learning about it.
My question on this thread is: do you find that things break in your scripts between versions?
I ask because I’ve already seen breakage in my scripts caused by version changes, both between 2.80 - 2.82 (somewhere) and 2.82.7-2.83.0.
I haven’t had time to track down what changed yet, but these are two different scripts, not very large, 2-300 lines, dealing with separate applications.
That this happened twice in quick succession made me wonder if it’s a common occurrence.
I do plan to track these down and post them separately, but I wonder if this is the norm I should expect, working with blender. With Maya, it’s pretty rare for things to break between versions, and I have decade old procedures which still work.
Cheers,
Jackie
It depends a lot on the kinds of actions the script does.
The answers people will give to this question depend a lot on the kinds of scripts they write.
If your script is using operators (bpy.ops.*
) and that operator is updated, then the script could break.
In general avoid using bpy.ops
where possible and edit the data directly, as it’s less likely to change between releases.
If your script uses an area of Blender which is being heavily updated, the changes may mean the script needs updating too.
Blender’s Python API closely maps to the internal data, so larger updates sometimes change the Python API too.
We’re aware of this issue and avoid unnecessary breakages between point releases where possible.
If you want a guarantee things wont break, best stick with LTS versions, otherwise some testing is needed between point releases.
All of the Python API changes are documented in the release notes. I haven’t noticed any big changes, recently, but 2.81 had a lot of miscellaneous changes which were essentially the result of bugs being fixed from 2.80.
