This is the second time I’ve gotten this error, on two different computers now with fresh dependency installations folders, so I’m confident enough that it’s repeatable to report it.
It seems to be not finding ilmbase
, but I do have it installed installed on the system. It mentions not finding pthread_create
in the error file but it looks like it actually is found.
Unpacking Alembic-1.7.8
-- The C compiler identification is GNU 9.2.1
-- The CXX compiler identification is GNU 9.2.1
-- Check for working C compiler: /usr/bin/cc
-- Check for working C compiler: /usr/bin/cc -- works
-- Detecting C compiler ABI info
-- Detecting C compiler ABI info - done
-- Detecting C compile features
-- Detecting C compile features - done
-- Check for working CXX compiler: /usr/bin/c++
-- Check for working CXX compiler: /usr/bin/c++ -- works
-- Detecting CXX compiler ABI info
-- Detecting CXX compiler ABI info - done
-- Detecting CXX compile features
-- Detecting CXX compile features - done
-- CMAKE SYSTEM NAME: Linux
-- Performing Test COMPILER_SUPPORTS_CXX11
-- Performing Test COMPILER_SUPPORTS_CXX11 - Success
-- Performing Test COMPILER_SUPPORTS_CXX0X
-- Performing Test COMPILER_SUPPORTS_CXX0X - Success
-- The install dir is /opt/lib/alembic-1.7.8
-- Looking for pthread.h
-- Looking for pthread.h - found
-- Looking for pthread_create
-- Looking for pthread_create - not found
-- Looking for pthread_create in pthreads
-- Looking for pthread_create in pthreads - not found
-- Looking for pthread_create in pthread - found
-- Found Threads: TRUE
ILMBASE_ROOT is undefined
CMake Warning at cmake/Modules/FindIlmBase.cmake:125 (MESSAGE):
Could not determine ILMBase library version, assuming .
Call Stack (most recent call first):
cmake/AlembicIlmBase.cmake:36 (FIND_PACKAGE)
CMakeLists.txt:223 (INCLUDE)
CMake Error at cmake/Modules/FindIlmBase.cmake:135 (STRING):
STRING sub-command REGEX, mode REPLACE needs at least 6 arguments total to
command.
-- ILMBASE INCLUDE PATH: /usr/include/OpenEXR
-- HALF LIB: /usr/lib64/libHalf.so
-- IEX LIB: /usr/lib64/libIex.so
-- IEXMATH LIB: /usr/lib64/libIexMath.so
-- ILMTHREAD LIB: /usr/lib64/libIlmThread.so
-- IMATH LIB: /usr/lib64/libImath.so
-- Skipping AbcConvert: it requires USE_HDF5
* Alembic Configuration ===
* USE_ARNOLD OFF
* USE_BINARIES ON
* USE_EXAMPLES OFF
* USE_HDF5 OFF
* USE_MAYA OFF
* USE_PRMAN OFF
* USE_PYALEMBIC OFF
* USE_STATIC_BOOST OFF
* USE_STATIC_HDF5 OFF
* USE_TESTS ON
* ALEMBIC_ILMBASE_LINK_STATIC OFF
* ALEMBIC_SHARED_LIBS ON
* ALEMBIC_LIB_USES_BOOST OFF
* ALEMBIC_LIB_USES_TR1 OFF
-- Configuring incomplete, errors occurred!
See also "/home/hans/src/blender-deps/alembic-1.7.8/CMakeFiles/CMakeOutput.log".
See also "/home/hans/src/blender-deps/alembic-1.7.8/CMakeFiles/CMakeError.log".
make: *** No rule to make target 'install'. Stop.
make: *** No rule to make target 'clean'. Stop.
ERROR! Alembic-1.7.8 failed to compile, exiting
If it’s helpful here are the two files it mentions:
Output: https://hastebin.com/uyefakaquj.coffeescript
Error: https://hastebin.com/uwijisuxiw.sql
