I have build the bpy
module in my site-package. But when I import the bpy, error occurs:
$ python example/render.py > output/render.log
A module that was compiled using NumPy 1.x cannot be run in
NumPy 2.0.0 as it may crash. To support both 1.x and 2.x
versions of NumPy, modules must be compiled with NumPy 2.0.
Some module may need to rebuild instead e.g. with 'pybind11>=2.12'.
If you are a user of the module, the easiest solution will be to
downgrade to 'numpy<2' or try to upgrade the affected module.
We expect that some modules will need time to support NumPy 2.
Traceback (most recent call last): File "/home/xzx/Project/RTCC/example/render.py", line 1, in <module>
import bpy
AttributeError: _ARRAY_API not found
ImportError: numpy.core.multiarray failed to import
The Numpy version used to compile and run is 2.0.0.
