@BYOB@AFWS@jesterKing@ankitm
I am trying to make an add-on which adds a node setup in Compositing workspace. But in the Add-on template I do not know how to change the location of bl_info to Compositor workspace.
“location”: “View3D > Add > Mesh > New Object”
I know View3D is for 3D Viewport. What is the ID name for Compositor workspace?
Since that part is only for human reading, you can write a jargon, not necessarily standard. When the add-on is ready to be submitted, brendonmurphy or Jacuqes or Doctor might be able to help.
@ankitm
What the name of the class I have to use. I know that I need to use class OBJECT_OT_<name> for manupulating in Object in 3D Viewport. What is the class name I need to use for Add in Compositor.
Let me make my question clear.
I see that you have used the name of the class as NODE_PT_add_compositor_node_tree. Is this name user-defined? If so, is there a convention to write the name?
